Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Blocking body lines
Old 03-08-2012, 10:15 PM
67Elcamino's Avatar
67Elcamino 67Elcamino is offline
Blocking body lines
Im attempting to perfectly block the bodylines on my project and wondering hot to built up low spots on the bodyline. Do I remove the tape, build up and retape the line or can I built with the tape in place. Im using featherfill G2 to build before blocking. Give this is a faily big low spot should I use polyester filler or shot featherfill?
Also I used laquer primer as a guide coat can I fill directly over the laquer guide coat? or should I sand it off first?
[IMG][/IMG] >
