blocking EGR ports on intake - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-06-2005, 10:15 PM
I was wanting to fill the ports on the intake (intake to head surface) with some of that epoxy putty to keep the exhaust out of the intake all together. The epoxy is Quicksteal and says you can use it on blocks, intakes, and exhaust. Has anyone used this stuff or similar on a high heat area? More info-aluminum intake for a 2.8l v-6 ford,ports are 3/4 by 7/8 inch, cant use a block off on top for lack of mounting area.
Old 05-06-2005, 10:19 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
block off plates
You can get restrictor and block off plates for the intake gasket. I would fabricate a plate to replace the EGR. I can't see a 1/8th" plate getting in your way.
Old 05-07-2005, 09:49 AM
lluciano77's Avatar
A lot of times the Felpro gaskets come with a knockout that you can leave in. It will block the passage between the heads and intake.
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 02:10 PM
Head recommendation - low HP w/LT1 intake Tim240Z Engine 0 07-08-2004 01:56 PM
Weiland 300-64 Intake EGR question tanager General Rodding Tech 0 05-25-2004 10:01 AM
egr intake 78 chevy truck Engine 3 09-15-2003 04:28 PM
Cam Help black66 Engine 3 05-12-2003 07:15 PM
