blocking polyester primer - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2007, 11:11 PM
what grit is everyone using to block polyester primer before a 2k primer?thanks...
Old 03-22-2007, 12:17 AM
willys36@aol.com's Avatar
Wiki Edits: 21
I use 320. K2 will fill those scratches very well.
Old 03-22-2007, 06:03 AM
I use 180 to cut the polyester primer. 180 is coarse enough to cut and level the surface, which is what you want to do. I usually do an initial cut on the 2K with 180 and then finish with 320.
Ed
Sealer or polyester primer first? Cowtown Punk Paint 20 06-20-2016 05:39 AM
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 03:07 AM
Rolling on polyester primer. MARTINSR Body - Exterior 15 05-31-2006 07:55 PM
Evercoat Slick Sand, Featherfill, G2, Polyester Primer Surfacer scrot Body - Exterior 6 05-27-2006 02:27 PM
polyester primer surfacer 62galaxiguy Body - Exterior 4 02-14-2004 08:27 PM
