Blotchiness - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2005, 06:46 PM
Blotchiness
is it normal for base coat to show blothiness spots, in other words it looks darker in certain spots than others, no orange peel or anythink, im just wondering when I go to put the clear on if it will still show up
Old 07-21-2005, 07:02 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
What kind of paint? Solid or Metallic?
Nason has a blotchy look till it flash's out completly.
Some metallic's will look "slightly" blotchy but will clear out fine.
Old 07-21-2005, 07:19 PM
it is kirker paint , bright red, no metallic
Old 07-21-2005, 08:05 PM
mrcleanr6's Avatar
make sure its dry and take some mineral spirits and squirt it on the surface and see if it goes away. the mineral spirits will emulate how it will look once cleared. most likely the blotchiness will stay. its covering poorly and will need more coats or be sprayed over a similar color base.
Old 07-21-2005, 09:37 PM
Yeah, if you're seeing light and dark spots with a solid color then the paint isn't covering completely. It needs more coats for complete coverage.
Old 07-24-2005, 05:58 AM
shine's Avatar
Last journal entry: some progress
are you painting over a solid coat of sealer or primer spots ? red does'nt cover well. best to tint your sealer
