Originally Posted by carsavvycook
It will cause it to come out of any cylinder. If it is just #2 shoot some carb spray into the pcv hole, with the valve removed. If the idle picks up, your intake gasket could be bad.
interesting...
Let me see if I got this right: If the PCV valve is bad or there is a baffle missing, oil is sucked up through the hose, into the rear carb vacuum port and out of any random cylinder exhaust port ?
As for your second suggestion. I shoot carb spray into the pcv hose (carb side) and not the actual valve cover right?
