Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Blow By on a fresh rebuild. Possible ?? PLEASE HELP. Pics inside
  #99 (permalink)
Old 09-23-2008, 10:19 AM
Sin7's Avatar
Sin7 Sin7 is offline
Originally Posted by Gassman
I think everyone is trying to over anilize this. Before I spent any money or tore into anything, I would change the oil, put stock valve covers on it and run the crap out of it. Running it under load should finish seating the rings and see what happens.
i hope you all you guys that have given me ideas dont take this the wrong way, but I do see eye to eye with Gassman... I'd much rather fix the simple obvious things like the baffle and oil before I rip the heads off.....
How hard is it though for a somewhat mechanically inclined like myself to replace the valve seals? I've never personally tore into a motor before.... The things that i've done this far are all new to me.
I will however continue the compression check on the remaining 6 cylinders to see what the entire motor is running....
