Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Blow By on a fresh rebuild. Possible ?? PLEASE HELP. Pics inside
  #149 (permalink)
Old 09-24-2008, 10:55 PM
j.d.brown.042964's Avatar
j.d.brown.042964 j.d.brown.042964 is offline
406 Caprice:Rust Never Sleeps!
Hi Luis; Sounds like things are looking up for you, and wifey has one less pair of shoes in that closet. Glad to hear that comp.readings were fairly well balanced across the board. If you're gonna' run it with PCV not recycling into manifold, you could just run a draft tube from it for temporary usage, and if "stationary", a coffee can could catch the drippings to give you an idea of how much is getting thru PCV valve. (Repeat test after baffle installed, for comparison). Anyways, glad it's coming along. -Jim
