Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Blow By on a fresh rebuild. Possible ?? PLEASE HELP. Pics inside
  #189 (permalink)
Old 10-01-2008, 01:15 PM
alittle1 alittle1 is offline
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Luis,
As I suggested, buy a permanent type furnace filter at Home Depot it is the type that has the synthetic weave (blue or brown, whichever) , cut out a small rectangle of it and remove the baffle, put it inside the baffle and put the screws back in. This will allow vapor to pass but limit liquid and reduce some vacuum.
The filter will cut with a good set of shears and is about one inch thick, this was good for my use.
To shift the transmission, start in low and run it up and change gears manually.
