Maybe I'll fix the baffle issue first and then run it.. Will the oil residue on the exhaust valve eventually burn off or is there an easier way to cleaning it? |
...lol... So it should burn off in a few days. I was thinking weeks.... |
Here is another thought I have, to see if it is the PCV causing the problem. Cap off the fitting on the carb, and run it at 3000 RPM for at least 15 minutes, if the oil smoke does not start to diminish, it will be the valve seal, or valve guide in #2 cylinder. Particularly the exhaust valve.
Did any of the plugs have oil on them? |
With his post, I wonder how far wide spread this problem is. |
none of the plugs had oil on them. They were nice and dry....even the #2 plug as previously posted.... |
Stephen |
it would be interesting to see what the common denominator is.... |
He cured his problem, with 2 o'rings on the valve it's self. |
Luis
There I feel better now that I got your name spelled right. There is NO OTHER forum on the internet, that can even come close to HOTRODDERS, in knowledge from experience. Soak it up, and "enjoy the ride". We are all here to help, and advise you, with any problem you come across, with your 'ride'. Stephen |
Luis,
You got mail. |
Hi Luis; Sounds like things are looking up for you, and wifey has one less pair of shoes in that closet. Glad to hear that comp.readings were fairly well balanced across the board. If you're gonna' run it with PCV not recycling into manifold, you could just run a draft tube from it for temporary usage, and if "stationary", a coffee can could catch the drippings to give you an idea of how much is getting thru PCV valve. (Repeat test after baffle installed, for comparison). Anyways, glad it's coming along. -Jim
| re-arrange pics in photo album | ChevelleSS_LS6 | Hotrodders Site Suggestions and Help | 7 | 01-25-2013 07:54 PM |
| Carb rebuild - won't start now. Please help? | joe99 | Engine | 6 | 11-30-2011 03:04 PM |
| GM steering column tilt/wobble repair HELP (pics inside) | camaroguy1969 | Suspension - Brakes - Steering | 18 | 03-05-2009 12:37 AM |
| Completed Stude interior pics... | phattpat | Interior | 6 | 07-22-2004 11:03 AM |
| bad headgasket as suspected.. pics inside... | Gino Fultano | Engine | 2 | 09-03-2003 06:56 AM |
