Blow By on a fresh rebuild. Possible ?? PLEASE HELP. Pics inside - Page 11 - Hot Rod Forum : Hotrodders Bulletin Board
  #151 (permalink)
Old 09-25-2008, 08:34 AM
Sin7's Avatar
Originally Posted by carsavvycook
Luis
There I feel better now that I got your name spelled right.
There is NO OTHER forum on the internet, that can even come close to HOTRODDERS, in knowledge from experience. Soak it up, and "enjoy the ride". We are all here to help, and advise you, with any problem you come across, with your 'ride'.
Stephen
lol no problem Stephen.
I can't say THANK YOU enough for all the help that's been provided.
  #152 (permalink)
Old 09-25-2008, 08:37 AM
Sin7's Avatar
Originally Posted by alittle1
Luis,
You got mail.
AMAZING WRITE UP... Thank you !!!!.... I know it will help me alot.
Originally Posted by j.d.brown.042964
Hi Luis; Sounds like things are looking up for you, and wifey has one less pair of shoes in that closet. Glad to hear that comp.readings were fairly well balanced across the board. If you're gonna' run it with PCV not recycling into manifold, you could just run a draft tube from it for temporary usage, and if "stationary", a coffee can could catch the drippings to give you an idea of how much is getting thru PCV valve. (Repeat test after baffle installed, for comparison). Anyways, glad it's coming along. -Jim
Yeah but she still deserves a little something for her help. Dinner and a movie maybe...
I'll fab something up to act as a temporary catch can...
  #153 (permalink)
Old 09-26-2008, 01:11 PM
Sin7's Avatar
I called Edelbrock's tech line two days ago and informed them of the problem I was having. I simply called to ask if they could sell me a set of baffles for the used valve covers I have. Mind you I didn't pay anything for the used valve covers. These were obtained on a parts trade...
Edelbrock's staff was so commited to helping me and this is what I got in the mail today FREE OF CHARGE !....
Pair of baffles, two grommets, 4 drive pins and 4 replacement allen plugs in a sealed bag....
  #154 (permalink)
Old 09-26-2008, 01:24 PM
Jmark's Avatar
Thats cool that they helped you out. Hopefully, that will fix the oil consumption.
I had a similar experience with Campbell Hausfield. I have an airless that I bought used. Been using it about 10 years. It developed a weird leak around a fitting that had a seal INSIDE. The fitting should not leak. I called and we both figured the main block had a crack inside. I asked how much, she said don't worry, i'll just send one out. I again told her the age and she sent it anyway, about a 200 dollar part! Made a believer out of me for that company!
  #155 (permalink)
Old 09-26-2008, 01:28 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Good deal Luis.
  #156 (permalink)
Old 09-26-2008, 01:43 PM
Sin7's Avatar
any company that is willing to bend backwards for a customer is Aces in my book....
Gonna spend this weekend working on this oil issue...
  #157 (permalink)
Old 09-26-2008, 02:06 PM
j.d.brown.042964's Avatar
406 Caprice:Rust Never Sleeps!
Good deal,luis. Great that they (Edelbrock) were so gracious. Sure can't ***** about the price, that's for certain! Good luck with the rest of sorting out the issues, and keep us all posted of your findings as you progress along. Have a great weekend. -Jim
  #158 (permalink)
Old 09-26-2008, 02:11 PM
great to hear
  #159 (permalink)
Old 09-26-2008, 03:50 PM
Wow!!!
What a thread this is!!! Glad I caught this one as I have a rebuilt 350 I'll be firing in the very near future! Thanks for all the tips and advice through this whole thread. Lot of good info before I turn that key~!
Name:	Bad *** 350 002.jpg
ID:	32873   Click image for larger version
Name:	Bad *** 350 003.jpg
ID:	32874   Click image for larger version
Name:	Bad *** 350 004.jpg
  #160 (permalink)
Old 09-26-2008, 04:21 PM
My 2 cents worth
Wiki Edits: 3
I'll bet you check those valve covers for 'baffles'
By the way, welcome
  #161 (permalink)
Old 09-26-2008, 05:52 PM
You sure know I did!!!!Drained the synthetic oil I had in there and flushed as well!!!!
Thanks for the welcome! Glad to be here! I have another thread going on a 54 Ford Coupe 351W I could use some help on as well!
  #162 (permalink)
Old 09-26-2008, 07:01 PM
DoubleVision's Avatar
Since I haven`t read every post, I `m not sure if this has been mentioned. You can`t run synthetic oil in a new build. I already seen the results of this. it`ll smoke, burn oil and won`t break in due to the synthetics anti friction characteristics. break it in with regular oil to about 2000 miles, then go over to synthetic.
  #163 (permalink)
Old 09-27-2008, 11:18 AM
I wonder how many people here, that are lauding the customer service of Edelbrock, have purhased or are thinking of purchasing the Edelbrock knock-off intakes, etc.
How has service been on the Crosswind, etc. knock off stuff?
How can Edelbrock supply that level of customer service if they have no customers?
BUY USA when possible.
  #164 (permalink)
Old 09-27-2008, 11:25 AM
  #165 (permalink)
Old 09-29-2008, 12:14 PM
Sin7's Avatar
Spent this weekend working on my issues....
I added the baffles to the valve covers
Cleaned the exhaust valve
Replaced the exhaust gasket
Changed the spark plugs
Dumped the Synthetic and added Mobil 10w40 and some Mystery Oil
Also added 4 oz to the gas tank... I had about 10 gallons in there.
Started the car up and it smoked for a bit... While it was running I sprayed some carb spray down the carb and pcv hose, engine stumbled a bit...
Drove it for about 5 miles and it continued to smoke. I'm assuming it's the burning all the oil that is in my exhuast pipe and muffler....Q: How long do you guys estimate it will take to burn all that out?
I did however notice that the throttle is a bit more responsive and idle is smoother.... Not sure if this is the mystery oil in action or because of the baffle and clean exhaust valve...
re-arrange pics in photo album ChevelleSS_LS6 Hotrodders Site Suggestions and Help 7 01-25-2013 07:54 PM
Carb rebuild - won't start now. Please help? joe99 Engine 6 11-30-2011 03:04 PM
GM steering column tilt/wobble repair HELP (pics inside) camaroguy1969 Suspension - Brakes - Steering 18 03-05-2009 12:37 AM
Completed Stude interior pics... phattpat Interior 6 07-22-2004 11:03 AM
bad headgasket as suspected.. pics inside... Gino Fultano Engine 2 09-03-2003 06:56 AM
