Blow By on a fresh rebuild. Possible ?? PLEASE HELP. Pics inside - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-22-2008, 02:54 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
If the intake gasket is not sealed right, and is sucking oil into the #2 port, by spraying carb spray into the valve cover, which is into the crankcase, your idle will increase, as the intake sucks it in through the leaking gasket.
  #17 (permalink)
Old 09-22-2008, 02:55 PM
Sin7's Avatar
Also, why would there be black residue (oil ?) coming out from the exhaust port at the manifold? Could I be juggling two problems like a faulty exhaust manifold gasket also?
  #18 (permalink)
Old 09-22-2008, 02:57 PM
Sin7's Avatar
makes sense. Should I let the car reach normal operating temp before doing this? Or can it be done as soon as I start the car ?
  #19 (permalink)
King of my Man-cave.
I don't think the Elite series valve covers come with baffles. The Edelbrock catalog specifically states that the Signature series does, but there is nothing stating the Elite series does. You have to install breathers into the Elite series.
I'm pretty sure your problem is with the valve covers and lack of breather baffles.
tom
  #20 (permalink)
Old 09-22-2008, 02:58 PM
My 2 cents worth
Wiki Edits: 3
With the black residue coming from the exhaust @ the #2 port, you do have a faulty exhaust gasket also.
  #21 (permalink)
Old 09-22-2008, 03:00 PM
My 2 cents worth
Wiki Edits: 3
It can be done hot, or cold.
  #22 (permalink)
Old 09-22-2008, 03:01 PM
Sin7's Avatar
tom
Thanks for that info Tom.
So if the passenger side valve cover does not have a baffle, what are my options? Raise the pcv with two o-rings like JMARK suggested ? If I add a breather to the passenger side valve cover, does this mean I'm eliminating the pcv system?
  #23 (permalink)
Old 09-22-2008, 03:02 PM
Sin7's Avatar
i'll put that on my list.
  #24 (permalink)
Old 09-22-2008, 03:09 PM
Sin7's Avatar
suppose I get home and after removing the header i notice that all 4 exhaust ports are "leaking oil", could I still be on the right track of a possible baffle or intake gasket issue??....
At this moment it's apparent that the exhaust manifold gasket at the #2 port is damaged becuase it's leaking. Wonder what #4,6 and 8 look like.....
  #25 (permalink)
Old 09-22-2008, 03:10 PM
Jmark's Avatar
If the PCV valve is in the drivers side of the engine, that cover needs a baffle under the hole. You can actually just pull the valve out and shine a flashlight in there and look. If you see the head, there is NO baffle. There "may" be bosses and holes in the cover for an "optional" baffle, if they did not come with one.
The cover that does NOT have the PCV valve does not really need a baffle. It's nice but not required.
Mark
  #26 (permalink)
Old 09-22-2008, 03:12 PM
Sin7's Avatar
Mark
in my case, the PCV is on the passenger side. The drivers side valve cover has the air breather.
  #27 (permalink)
Old 09-22-2008, 03:16 PM
My 2 cents worth
Wiki Edits: 3
If you think it might be the rings, with the pcv out watch for oil smoke coming out of the valve cover. This is called blow by.
  #28 (permalink)
Old 09-22-2008, 03:19 PM
Sin7's Avatar
Cool.. I'll definately be looking out for this...
  #29 (permalink)
Old 09-22-2008, 03:25 PM
Sin7's Avatar
Carsavvycook - Forgot to ask how much carb spray should I spray into the pcv hole? I dont wanna over do it....
  #30 (permalink)
Old 09-22-2008, 03:55 PM
My 2 cents worth
Wiki Edits: 3
Just spray for about 15 seconds.
re-arrange pics in photo album ChevelleSS_LS6 Hotrodders Site Suggestions and Help 7 01-25-2013 08:54 PM
Carb rebuild - won't start now. Please help? joe99 Engine 6 11-30-2011 04:04 PM
GM steering column tilt/wobble repair HELP (pics inside) camaroguy1969 Suspension - Brakes - Steering 18 03-05-2009 01:37 AM
Completed Stude interior pics... phattpat Interior 6 07-22-2004 12:03 PM
bad headgasket as suspected.. pics inside... Gino Fultano Engine 2 09-03-2003 07:56 AM
