Blow through fuel system. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-26-2010, 02:06 PM
Originally Posted by zildjian4life218
Yeah So your thinking at least 20 psi and 50lb/hr
No. 50lb/hr AT 20psi. (not "and" but "at). THERE IS A HUGE DIFFERENCE. One is two arbitrary points, the other is a single point on a pump curve.
  #17 (permalink)
Old 10-26-2010, 02:25 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
right yeah i misspoke.
  #18 (permalink)
Old 10-26-2010, 02:31 PM
When you go to buy a pump a lot of marketing will also "misspeak" as most electric pumps will hit 20psi and 50gph, and fewer will hit 50gph at 20psi. To be honest though you can probably do it with a pump out of a newer full size car or truck. You'd be surprised at what those pumps can deliver when they're not running at 45psi. Sometimes if you do enough research and ask the right people you can get pump curves for stock pumps, sometimes its a $15 risk when you walk out of the junk yard with one.
  #19 (permalink)
Old 10-26-2010, 02:35 PM
Listen and Learn
Wiki Edits: 7
Do any newer cars have external inline pumps? I would like to do this instead of having to get a universal intank setup.
  #20 (permalink)
Old 10-27-2010, 09:19 AM
Listen and Learn
Wiki Edits: 7
or this
http://www.racingjunk.com/category/1...ries-pump.html
http://www.product-engr.com/PE_4500.htm
Should be plenty of pressure and flow but i don't know the conversion of lb/hr to gph.
Idea for a future big block build RamAirZ Engine 3 09-04-2009 05:01 AM
street rod fuel system czmpjx General Rodding Tech 2 11-26-2007 12:58 PM
carburetor leaking; fuel tank needs cleaning islandman General Rodding Tech 7 03-17-2007 06:03 PM
Fuel System 41willys General Rodding Tech 2 10-08-2005 08:17 AM
Carb size to small???? brainsboy Engine 50 08-14-2005 04:04 PM
