Blowback through carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-16-2012, 06:20 AM
Having difficulty tuning my rebuilt 327. Engine is knocked up with race performance internals and is the first time I've ever tried tuning a motor this hot. Whenever I try to start the engine, mostly when it's already warm, I have to crank it over and over and play around with pumping the gas pedal. Sometimes I have to pump more than other times and sometimes I don't have to pump at all and it will fire up. But most the time when it tries to start, burnt gas fumes and un-burned gas come jumping back out the top of the carb. Lots of smoke and really embarrassing! Whenever i use a shot of starter fluid then crank it over, it fires right up. I've adjusted timing and even main jets on carb. which is a QFT 680. Could I possibly have the wrong aluminum head spark plugs or maybe not enough spark? I have a 12:1 compression, mallory distributor w petronix II ignitor and a 40,000 V coil.
Old 12-16-2012, 07:28 AM
When it "fires up" on starter fluid, does it run after that or does it shut down after a few seconds?
What is the ignition timing set at?
What pistons and heads are you using?
Old 12-16-2012, 08:56 AM
Infomaniac's Avatar
Twin Turbo Drag Boat
Last journal entry: Random In Progress Shots
Sounds a lot like a blown powervalve.
Old 12-16-2012, 09:22 AM
Post all the information you can about your motor. Brand of crankshaft, rods, pistons, head gasket compressed thickness or part number, brand and type heads, , brand of spark wires, type of spark plugs AC R45, part number of camshaft and type, hydraulic or solid tappet or Roller cam. Who built the motor? Who setup heads. Have you checked for vacuum leaks? Spray starting fluid all around intake flange and carburetor base at gasket. If idle goes up you have a leaking gasket. Tools you need are a vacuum gauge and timing light with advance. (has a knob on back end) Check spark plug wires with multimeter to see if you have continuity. What kind of car or truck (year and make) is the motor in? Read this article on HEI distributors and timing. http://www.crankshaftcoalition.com/w...EI_distributor Use the vacuum gauge to set idle mixture screws. Make sure your fuel pump pressure to carburetor is about 5-5.5 psi. How or what adjustments did you make to the jets on the QFT 680? Has the engine back fired thru the carburetor if so you may need to replace power valve. Get a vacuum reading at idle. If the reading is say 10 divide by 2 = 5. Use a 4.5 power valve. Here is the instructions for your carburetor. http://www.quickfueltechnology.com/I...ons_Rev._1.pdf
holley carb backfires threw carb talleyho Engine 63 01-04-2016 11:43 AM
Will adding a 1 inch carb spacer affect carb tune? eric32 Engine 29 02-09-2010 01:13 AM
Quadrajet Carb rebuild....parts interchange with another junk carb? Warrant Engine 2 07-31-2006 11:44 PM
94 f150 with oil blowback dptyscott Engine 3 07-20-2006 07:44 AM
Any problems spraying carb cleaner in my carb while its on the motor? batman09 Engine 11 11-29-2005 08:49 AM
