Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Blowby Problem
Thread: Blowby Problem
Old 09-22-2005, 09:37 PM
Kevin45's Avatar
Kevin45 Kevin45 is offline
Just one of the guys
Last journal entry: Vise jaws
The rings could be installed incorrectly, youo could have a scored cylinder, or you could have a buildup around the ring not allowing it to do it's job. Drain a quart of oil out and toss in a quart of tranny fluid. The trannie fluid is high detergent, Drive it for 200 miles and do an oil change and see if it makes any difference. If per chance you have a build up around the rings this should clean things up[.
