Blowby Problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2005, 08:43 PM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
Blowby Problem
I'm having a bad blowby problem with the motor in my T Bucket.
I took an EFI 302 from a van and freshened it up with rings and bearings and transplanted that into my T Bucket. The cylinders were in great shape with no noticable ridge. I have the el cheapo chrome valve covers and el cheapo chorme breather on the front of the drivers side cover. The PCV valve is on the back of the passenger side cover and connects to the stock fitting on the intake manifold, so I should have a good crossflow and good vacuum through the motor. This setup worked perfectly for about 3000 miles, nothing comming out of the breather and no oil dripping. All of a sudden I started getting oil mist from the breather. Of course the oil ends up on my windshild cause it's a T bucket. I've replaced the PCV valve three times and the vacuum hose to it with the same results. It's not bad under idle or low load, but going up hills, it's fuming and spitting oil out. Another 1500 miles and I'm still messing with it.
Now a couple things come to mind. Either all the PCV valves I'm using are junk, or my motor is all of a sudden blowingby excessive exhaust gas.
Now I have temporarily fixed the problem by eliminating the PCV valve and piping the vacuum directly to the valve cover. I put a small restriction in the hose as to not bleed off too much vacuum from the intake. This works great, but now all that exhaust gas is being sucked into the intake (which it probably was all along, I just didn't know it). How much blow by is normal anyway? I think I will do a compression test to see if I lost any cylinders. Should I get a breather that has a hose to the air cleaner? Will I just end up with oil in my air cleaner?
Any Input?
Old 09-22-2005, 09:15 PM
T bucket.Even a very small ridge can crack rings and pistons.I hope it is not the case.Forget about the compression test.Do a "leak down test" using a good instrument.It will diagnose better.Anything more than 30% means serious problems.Or maybe the rings are not correctly installed?
Old 09-22-2005, 09:25 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Go to Jegs or somewhere like that and order some baffled gromets for your valve covers. Then replace the ones you have now with the baffled ones, onr for your oil breather and one for the pcv valve. The cheap valve covers to not have baffles under the cover for those openings. So the baffled grommet is the way to go with them. Without them oil coming out that breather is normal.
Old 09-22-2005, 09:37 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
The rings could be installed incorrectly, youo could have a scored cylinder, or you could have a buildup around the ring not allowing it to do it's job. Drain a quart of oil out and toss in a quart of tranny fluid. The trannie fluid is high detergent, Drive it for 200 miles and do an oil change and see if it makes any difference. If per chance you have a build up around the rings this should clean things up[.
Old 09-22-2005, 10:27 PM
docvette's Avatar
Wiki Edits: 12
Blowby
Doc here,
How much blowby do you have? a little is a common byproduct of combustion...How new is the engine?
Is it possible the rings have not seated, or seated properly? how did you break it in?
First if you eliminated the PCV for straight vacuum your heading for trouble..that blow by, over time, will turn to straight blue smoke out the pipes, fouled plugs and it will run like crap in a can...as you will be sucking straight oil into the induction system and burning it.
The valve is designed to be a one way valve, and shut off as soon as the vacuum is relieved (off idle, acceleration) when the vacuum is low AND oil pressure is high. Put the valve back in..or block it off altogether..Plus even with the restriction , it can't be too good for the vacuum volume.
Next, Was the Valve cover cap on the opposite Valve cover vented? If not therein lies your problem...The PCV MUST travel across the engine to pull blowyby out..If it's blocked off (no breather ) it will only breathe until the pressure is equal at the valve and crankcase, then become a "Vacuum canister" that will blow gaskets over time.
Put a vacuum gauge on the tap and see what you actual vacuum pressure is..should be a STEADY 17 to 20 In Hg at idle and decrease with throttle..(unless you have a real Lopy Cam..)
Baffles, as Henry Said, are important, especially with an engine that has an overactive top end oil system..and "Shortie Valve Covers" you can get a breather cap with a baffle installed in the cap (which is nothing more than a cap with a steel wool like substance inside of it..) but on the PCV side you should have a Valve cover baffle, or baffled grommet.
Try that, see what transpires..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 09-23-2005, 12:07 AM
BstMech's Avatar
NYOFP4RJ3CHRIS
Check to make sure the vacuum port for the PCV isn't restricted from gunk.
Old 09-23-2005, 07:16 AM
cboy's Avatar
Last journal entry: Finished
Arrowhead,
Here is a pretty good thread explaining how your PCV system OUGHT to be working. diagnosing blow by issues with 460
Included in that thread is this handy dandy backyard test to determine if your PCV system is working. (Kudos to NXS and Kultulz for the original info.)
1) This morning I first checked the vacuum at the hose running from the carb base to the pcv valve and had 19 inches of vac. - so that looked good.
2) Per NXS's advice, I disconnected the hose from the carb to the pcv valve and plugged the pcv valve outlet and the vacuum stub off the carb. With the engine at idle I then pressed my palm over the oil filler/breather cap hole and held it there about 10 seconds. When I lifted my had I would get a definate puffing from built up pressure...but no smoke of coloration in the air being blown out.
3) I then added a bit to NXS's troubleshooting guide. I once again attached to hose from the pcv valve to the vac stub on the carb and ran the "palm over the breather hole" test again. And I STILL got pressure build up and a puffing when I removed my hand. And from Kultulz's explanation, I don't think that is supposed to happen and might indicate a faulty pcv valve.
Dewey
Always learning...and sharing what I've learned.
94 Dodge Transmission Electronics problem? Native Gearhead Transmission - Rearend 7 10-17-2006 11:00 PM
Wiring problem is driving me crazy pmeisel Electrical 7 07-12-2005 08:45 PM
Problem batch loading larger images cboy Hotrodders Site Suggestions and Help 10 03-23-2005 09:26 PM
*&%##*^#!! starter problem solved!!!! 85 vette Engine 12 02-22-2005 09:12 AM
Newest Transmission problem RObs71Nova Transmission - Rearend 4 01-30-2005 08:00 AM
