Blowed a fuse... why? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2012, 04:35 AM
staleg's Avatar
Last journal entry: Home made gear stick
Tested the newly wired harness yesterday.
Before the test I checked for draw with the plus cable fastened on the battery and a test lamp between the minus battery pole and ground. No light.
Discovered that the headlight switch is broken. No park lights and no rear lights at all. Only the headlights works. Bench tested the switch to be sure
Have ordered a new switch.
When I tested the flasher signal, the fuse blowed after app 10-20 seconds.
Could that be because of the non functional headlight switch?
The car has the usual flasher/brake light/rear light in the same bulb.
Old 08-28-2012, 06:52 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Are you talking 4 way or turn signal? They use different flashers. Was the fuse rated high enough?
Old 08-28-2012, 07:04 AM
staleg's Avatar
Turn signal.
The fuse was the original one from EZ wiring.
Old 08-28-2012, 08:01 AM
staleg's Avatar
The fuse was 15 amp.
Old 08-28-2012, 08:15 AM
Irelands child's Avatar
If you are using Vintique brand lights, take a look at the Chinese made headlight bulb connectors as well as the taillight bulb sockets. I have had very poor luck with several and needed to replace with commercially available parts as they can be dead shorted - and of course blow fuses.
Dave W
Old 08-28-2012, 09:12 AM
staleg's Avatar
Thanks for the input, but none of the working turn signal flashers are chinese. They are from the scrapyard, tow. If the trouble goes on. Ill try to disconnect one by one of them.
One more thing, by the way! One of the lamps is a LED lamp. and first I wasn't aware that ground and plus must not be mixed on LED lamps.
When the fuse blowed, I had this mixed up. I thought is was none working. Maybe this can create a small dead short tat after a while will blow the fuse?
Old 08-28-2012, 11:02 AM
Most probably not unless one was defective.
Old 08-29-2012, 02:06 PM
staleg's Avatar
No it wasn't. They both worked fine when I got the wiring correct.
fuse lacas53 Electrical 1 01-17-2012 03:41 PM
Keeps Blowing Fuse hotrod48 Electrical 17 09-29-2005 12:20 PM
Fuse Block Nic1979 Electrical 8 08-09-2005 01:21 AM
Fuse or What mann1961 Transmission - Rearend 0 06-15-2004 05:59 PM
