blower on a 383 stroker question!
I am going to build a 383 but would like to put an 8-71 blower on it. what would be the best for pistons and cam and what else would I have to do to make it blower worthy? thanks alot for any advice
It will be going in my 85 elcamino. I want it to be street/strip on pump gas. I am working with about 10k. Just for the motor the trans and rear are for another time.
wow thanks that helps alot!! It sounds like I can go through them with all my engine build parts! Do you think that 10k is enough?
You should be able to build a nice blower motor with 10K. That's about what I have in mine (355) using a race-prepped short block (Eagle steel rods and crank, KB blower pistons), Dart Iron Eagle S/S 76cc heads (8.2:1 c/r), Comp hydraulic roller cam (224/230 @ .050, 112 LSA), BDS 6-71 polished kit w/ pullies for 6# boost), 2x Edelbrock 1405s, polished Hilborn-style scoop, polished Weiand water pump, MSD billet dizzy, 6AL box w/ a 6000 pill, Blaster II coil, 8.5 plug wires, chrome Slamguard oil pan (3.5" clearance
), chrome starter, chrome alternator, coated roadster headers. |
what kind of power you pushin?
The guy that built my short block (his engine shop specializes in circle track and street rod motors) estimates 500 hp, 450 torque. All I know is it's way more than my light little car can put to the ground!
Spend the money you would have used on a 383 stroker kit, on a really good set of cylinder heads and build a low compression 355ci motor with forged dished pistons
TRW L2441F-30 pistons (21.1cc D dish) 350 4 bolt 010 block bored .030+ bore "0 Decked" New GM 5.7" rods and ARP bolts New 3.48" stroke cast steel crank. Get the crank and balancer cut for a double keyway for the blower drive. Use a aftermarket balancer like a ATI SuperDamper. http://www.atiperformanceproducts.co...pers/index.htm Use AFR 195cc 76cc chambered eliminator heads. EG: AFR pn 1036. Crane cam #113801 Hyd flat tappet with a 1.6/1.5 split rocker ratio set. Mild street manors near stock converter. good supercharger power to 5500-6000rpm. Crane #114681 blower friendly mechanical street cam http://store.summitracing.com/partde...1&autoview=sku 3000stall good street manors strong, strong power to 6500++rpm. use two blower modified 750cfm holleys or two modified 750cfm edelbrock carbs. Your compression ratio will be 7.84:1 which will easily allow 10-12 LBS of boost on pump gas with little or now spark retard and full reliability on premimum pump gas. |
You need to keep the compression down, to around 140 per cylinder, for longevity on the street/strip, when using straight up 1.1 ratio, or higher boost levels (over driven).
A 1.1 ratio will work with up to 170 compression for the street, but not recommended on the strip, unless you run racing fuel's of 108-112 octane, for both. Personally I recommend a under driven ratio, to no more then 9 LBS of boost, with up to 170 compression. Another "must" is the use of a boost retard controller. I prefer MSD's controller's, personally. The corvette in my AVATAR, is a 383, it has 170 compression, running a 1.1 ratio. The boost retard is set to 1" retard for each pound of boost. It also runs 112 octane fuel, but never sees the track. |
Your money is much much better spent on Blower carbs/fuel system, a good well designed exhaust, a quality transmission and torque converter and dyno tuning and set up. Keep it simple...... |
| 350 or 383 Stroker? | my350camaro84 | Engine | 19 | 07-30-2012 07:44 AM |
| 383 stroker question | deeloccb15 | Engine | 3 | 09-18-2006 01:01 PM |
| 383 Stroker Buildup | low77ride | Engine | 8 | 02-09-2005 08:46 AM |
| HEI or full MSD on 383 Stroker? | my350camaro84 | Electrical | 5 | 02-07-2005 08:04 PM |
