Blower Carb CFM? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2010, 04:13 AM
QParker's Avatar
Six Offender
Blower Carb CFM?
I took this off the BDS site:
http://blowerdriveservice.com/faq.php
It says :" To measure CFM on a blown engine:
{(CID x RPM) ÷ 3456} x {Boost ÷ 14.7) + 1} = CFM required.
So on a 292 I6 spinning 6000RPM w/ 10#'s it'd be:
(292x 6000)÷ 3456x (10÷ 14.7)+ 1= 851CFM Right?
P.S: where the #?*! is the #?*!ing divide key on the key board? I just copied and pasted the one from the link...
Old 07-29-2010, 04:14 AM
QParker's Avatar
Six Offender
I also found this to find the final compression ratio:
Final Compression Ratio (FCR) = [ (Boost÷14.7) + 1 ] x CR
That would mean I'm running around 14:1 compression with 8.5:1 base and 10 lbs boost...
Maybe I'd better go with 8:1 to bring it down to around 13:1...
Old 07-29-2010, 06:08 AM
techinspector1's Avatar
Wiki Edits: 326
8.0:1 SCR and 8 lbs boost should be pump gas friendly, assuming you built in a good squish and rounded all sharp corners in the chamber.
Old 07-29-2010, 06:32 AM
345 desoto's Avatar
Location: Skaneateles, NY Summer/Port St.Lucie, FL Winter
I'm running 2 500 CFM Carter Competition series carbs with 5 lbs boost on a 291 Hemi, and it goes like a scalded dog...
Old 07-29-2010, 01:05 PM
bigdog7373's Avatar
Of course it's fast
The divide button is a forward slash.
blower carb kwopper07 Engine 1 02-10-2008 10:27 PM
750 cfm carb - tuning - smaller jets or 600cfm? 65truck Engine 8 01-20-2004 07:13 PM
holley 600 cfm carb ap0001 Engine 9 01-17-2004 10:30 AM
ENGINE, Blower, Pistons, Heads, Carb, Distributor, and more 84Z Hotrodders' Lounge 0 12-21-2003 11:54 PM
what makes cfm in a carb fordracing Engine 3 04-01-2003 11:01 AM
