-   -   blower carb PV test (http://www.hotrodders.com/forum/blower-carb-pv-test-219506.html)
Blown496 05-17-2012 12:56 PM
blower carb PV test
Should the manifold ref pv's hold vacuum using a hand pump? I can mighty vac past the pv value but they both bleed off slowly. Before installing them I could hold vacuum on my tongue with them. The engine is responsive to idle screws and is not pig rich. Is it enough vacuum leak to be an issue?
Thanks
2x4 Barrels 05-18-2012 08:35 AM
yes
1 Attachment(s)
Hi 96
Yes the valve`s should hold vacume.
2x4`s
