blower carb PV test - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2012, 11:56 AM
blower carb PV test
Should the manifold ref pv's hold vacuum using a hand pump? I can mighty vac past the pv value but they both bleed off slowly. Before installing them I could hold vacuum on my tongue with them. The engine is responsive to idle screws and is not pig rich. Is it enough vacuum leak to be an issue?
Thanks
Old 05-18-2012, 07:35 AM
yes
Hi 96
Yes the valve`s should hold vacume.
2x4`s
Can I Do An Accurate Compression Test With No Carb? Hoyt71 Hotrodding Basics 2 11-14-2011 04:21 PM
Rochester carb with blower LordTTK Engine 9 08-27-2008 03:51 AM
Blower Carb S10 Racer Engine 3 04-27-2008 05:11 PM
blower carb kwopper07 Engine 1 02-10-2008 09:27 PM
Carb + emission test 327 Walker Engine 1 07-17-2003 12:49 AM
