Blower engine questions? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2009, 03:04 PM
Hi
I have an old, stock bore, 2 bolt SBC (3970010) with 3998920 smog heads (1.94/1.5 valves 76cc) that Im planning to rebuild and supercharge with a weiand 177.
Can I reuse the cast crank and rods and will the 2 bolt mains be a problem? A ARP main stud Kit would help, wouldnt it?
I will be using forged pistons.
Its only going to be a fun street machine not going over 6000 RPM with hopefully 450-475 HP on crank.
Any ideas and suggestions are welcome
Old 05-25-2009, 12:50 PM
Originally Posted by F-BIRD'88
A Lunati street cam such as this one will make great power and rpm with the 177 and drive easy on the street.
Thanks alot for your reply
I run a manual transmission (muncie), will that be driveable with that cam? (2400 RPM stall)
Old 05-26-2009, 08:31 AM
Yes its a very street friendly cam.
Nice, how about the heads?
I found an old thread where you recommends a set of WP 200cc Sportsman II 72cc heads instead the smog heads. Will my HP with those heads exceed the strength of my crank, rods & 2 bolt block?
Rebuild and port old GM sbc low comp heads for blower setup
Old 05-26-2009, 01:27 PM
Banned
if you're looking for 475 hp and 6000 RPM max then you really don't need forged pistons, aome good quality cast ones would be fine, and in some ways even better in your application- not to mention cheaper. Just make sure your tuning is pretty close to optimal and your not running too much timing or too lean of a fuel mixture (nor overly rich).
Old 05-26-2009, 01:40 PM
well, actually I would like to have as much hp as my block and rotating assy can handle... I was just thinking 450-500 hp was about it?
I going to install a MSD-BTM, A/F meter and probably also a knock sensor to hopefully prevent me from blowing it up
Old 05-26-2009, 01:50 PM
Banned
That probably is a good ROT, especially with those heads. If you want to go over that then you'll need a very well prepped factory block, or an aftermarket one. pistons are not your limiting factor though and improving in that single area really won'd do much for you. cast pistons expand less and in a lot of cases weigh less- two big advantages. They are weaker than forged, but at your limited level not really necessary.
Old 05-27-2009, 08:44 AM
Thanks for all the good advices. 94-95 octane are commonly available overhere so I just stick to that.
Valve Lash adjustment hiball Engine 36 05-11-2009 11:12 AM
871 Blower questions Lafayettej3 Engine 4 08-13-2008 01:47 PM
SF oil???? n-gin Engine 6 07-09-2008 02:37 PM
Chevy engine questions fred franklin Engine 6 03-29-2007 01:10 PM
Chevy engine questions fred franklin Engine 1 03-28-2007 12:21 AM
