Blower gurus HELP please! - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2006, 03:59 PM
Simple question , ok kinda
Im building a Chevy 350 8.5 to 1 compression with a Weiand 6-71 supercharger, Dart iron eagle heads 202/160 valves.
I have a 37 tooth pulley and a 32
I have been looking at various tables on different web pages and I want to double check with you guys.
If I run the 37 on top and 32 on the botttom, what would my compression raise too? How much boost would that be and how much under driven would my set up be?
Thanks Guys, hope to fire this engine up soon.
Duke
Old 03-03-2006, 04:16 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
My setup is 38 upper n 34 bottom and I make 11-12lbs of boost. But....The guys said with my setup (similar to yours) that I will only see about 8lbs.
Id guess that your looking at 5-6lbs???
Royce???? HG
p.s. Nice car!
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 03-03-2006, 04:50 PM
Infomaniac's Avatar
Twin Turbo Drag Boat
Last journal entry: Random In Progress Shots
8mm or 1/2 pitch pulleys?
Old 03-03-2006, 04:53 PM
Infomaniac's Avatar
Here You Go Man
Old 03-03-2006, 05:50 PM
1/2
Ive been to the BDS site, but im double checking
Old 03-04-2006, 09:06 AM
Infomaniac's Avatar
Its right there man. 13.5 % under drive gives 2 lbs of boost.
2 lbs and 8.5:1 gives you 9.7:1
Blower timing bailey40ford Engine 8 12-19-2011 05:58 PM
Shelby 427 Alum. Fuel Injected Blower Stroker Engine mustangwizard Introduce Yourself 2 01-10-2006 10:15 PM
Thinking about a small supercharger... Blazin72 Engine 11 12-21-2005 11:37 PM
blower problem fatrat96 Engine 7 07-05-2005 09:28 PM
Toyota Camry Blower Motor Problems donemore2003 Electrical 12 11-11-2004 11:45 PM
