Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - blower idle rpm problem
Old 07-01-2006, 10:12 AM
blownalkybbc blownalkybbc is offline
blower idle rpm problems
good advice from everyone so far, one thing you have got to do is get some fire in that motor, an old points distibutor is not going to do it, at the very least get an HEI with a 50,000 volt coil or better yet set up a crank trigger system with an msd box and coil, the best thing would be a mag system, of course we can only guess with out being there but for sure with the irregular idle either the fuel or the fire isn't consistant, i have messed with blowers for a lot of years and the best fuel system for either street or strip is the enderle injected systems, good luck
