blower motor base compression ratio - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-23-2007, 07:12 PM
fbodyfreak's Avatar
Who loves burnt rubber
Can anybody tell me what the best starting compression ratio on a sbc with a 6-71. What is the lowest compression I can run and still be able to start the engine and run 91 pump gas. I understand boost pressures can be changed.
Old 08-23-2007, 07:48 PM
techinspector1's Avatar
Wiki Edits: 326
If I were building one today, I'd build it 8.0:1 to 8.2:1, depending on the parts combination.
The more static compression ratio you build into the motor, the less boost you can run.
Old 08-23-2007, 08:24 PM
i agree with techinspector, aruond 8-1 for street. basic rule with blowers is the lower the compression the more boost you can run and the more power you make.
with a blown motor you are shooting for the same compression as a na motor but with lower compression you have more volume at tdc that the blower can force extra AF into to bring the compression back up more AF= more power.
example:
10-1 normally aspirated
8-1 compression, blower raises compression 2 points= 10-1
7-1 compression, blower raises compression 3 points= 10-1
6-1 compression, blower raises compression 4 points= 10-1
4-1 compression, blower raises compression 6 points= 10-1
each one of these put more mix in the chamber than the one above it and produces more power than the one above it.
Old 08-23-2007, 08:31 PM
fbodyfreak's Avatar
blower compression ratio
what compression ratio would be optimal to use a decent amount of boost and still run 91 octane fuel
Old 08-23-2007, 08:51 PM
read inspectors and my post above and figure it out, as we said a lot of guys run around 8-1. there is no such thing as an optimal compression and decent boost describes nothing, that like me asking "i have a glass of water in front of me, how much water do you think is in the glass??" read my post above until you understand it. pick a compression and use the blower boost to raise it up.
Old 08-23-2007, 09:57 PM
Wiki Edits: 326
See this chart from Blower Drive Service, it will give you the max boost for pump gas at a given static c.r.
For instance, at 8.0:1, max 8 lbs of boost.......
http://www.blowerdriveservice.com/techcharts.php
compression ratio compared to compression PSI squids1 Engine 14 12-28-2010 11:36 PM
Compression Ratio with 64 cc heads & Federal Mogul Sterling 345np Houman SS '70 Engine 9 05-01-2005 11:42 AM
Lower compression for blower Jim69Mustang Engine 6 01-13-2005 01:32 PM
compression ratio on blown sbc? Marcus Engine 2 09-19-2003 01:09 PM
Overheating?? & Question on blower ratio? chamz_16_2003 Engine 4 08-27-2002 01:05 PM
