Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Blower Motor blows fuses on high
Old 01-20-2013, 07:51 PM
walt03 walt03 is offline
I got it fixed.
It turned out to be a bad fitting line fuse holder that once changed by a previous owner, An after market lock end pigtail was used with the original GM fuse holder.
Looking closely you could see the nylon fuse holder had burn discoloration and only after getting it to work and blow more fuses I decided to replace it with a completely new fuse holder and crimp it into the old line.
It worked
Thank you to all people giving me tips on how to trouble shoot this.
Each one helped.
The blown fuse on the cigarette lighter and glove box was the result of some black tape falling off a female aftermarket connector in the heat of the summer and shorting out against the radio case.
You guys are great and I really appreciate you coming to my rescue,
My son-in-law and grandson learned a lot too.
Walt
