Blower motor not working - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2005, 02:32 AM
motoxracer's Avatar
Hi I have an 86 Chevy conversion van and my power windows and blower motor just stoped working,I have checked the blower mtr it is ok works if I jump it and have checked all the fuses all ok,being a conversion van I figure they jumped into a power line to get the power for the windows someplace.I havent checkd the blower relay yet but if that isen't it any one ever run into this problem before.
Old 01-28-2005, 06:58 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
wiring
I think the windows and blower may be on the accessories circuit. Which is usually the silver metal fuse. It's a 30 amp. Cannot be checked visually. You have to check it with an ohmmeter.
The only other problem I have had that was similar had to do with storing the vehicle over the winter. Moisture had corroded all my fuses. I removed them, cleaned the prongs, replaced them, and everything worked.
Old 01-29-2005, 02:19 PM
motoxracer's Avatar
Thanks for your reply I did find the problem bad connection in a conector hot lead from fuse box to the control unit.
Thanks Jeff
