Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Blower Motor Questions
Old 09-29-2012, 05:36 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
Its also a possibility that the engine has blown head gaskets before and when it was repair a different gasket ended up there.next time a situation like that comes up,put a rad pressure tester on the rad and run the engine to see if pressures build up fast when the engine is cold.
Is there any indication of one or 2 side by side pistons being steam cleaned?
