Blower motor set up questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2009, 10:50 PM
Bad Rat's Avatar
Last journal entry: Bad Rats anglia Build Journal plus bike and other photos
Wiki Edits: 2
I am putting a 468 BBC blower motor together for my Anglia
I have a set of Gm cast oval prrt heads #3336 (781) 118cc chambers and the blower is a 420 B& M with rect ports,,
I read a article about the matching the oval ports to the rect blower ports,, using 1211 flopro gaskets and got better flow # up to about 6K rpm, here
http://www.maliburacing.com/patrick_budd_article.htm
flow comparason here http:// www.maliburacing.com/ovalvsrect.htm
The cam I have is a comp #11-414-8 blower/ Nitrious, 566 In and 575 ex with a lobe sep of 113* duration 242 int and 254 ex
and 8'5 comp full hyd roller
any ideas from you blower guys aboutwhat size and type of Carbs would be best for this motor? also have a carb plate nitrous kit for it
this one http://www.summitracing.com/parts/NO...S/?image=large
any ideas please,, I posted over on a existing thread on blowers but it got so far down the list that it got no replys,, Thanks bIll
Old 11-17-2009, 01:39 AM
471A
blower carbs
Search "backfire blower" within the HBB websit, and it will tap you into a thread 471A began with nightmare problems in setting up the carbs on a Weiand/Holley 250 blower atop a SBC 355. The info I received through HBB solved problems that had me close to giving up. You will find in that thread three or four regular HBB contributors with superb knowledge about carb setups for blowers. In my particular case, I run dual four-corner boost referenced Holley 600s where the key proved to be ignition timing. Once I went locked in 34 degrees, backfires no longer were a problem and the SBC fires reliably in weather cold or warm.
Old 11-17-2009, 02:26 AM
ericnova72's Avatar
More for Less Racer
There was nothing in the referenced Patrick Budd article link about grinding the oval intake ports to the rectangular shape??? Just a test of two entirely different heads, one Rect port LS-6 heads (026 casting) and the other just common '70's oval ports (781 casting).
Old 11-17-2009, 02:36 AM
Bad Rat's Avatar
Wiki Edits: 2
Eric,, That infromation is in this link,,
the 781 oval ports are the same as the 049 cast heads except for the 781 have 118 cc chambers and the 049 has 122 cc chambers and slightly larger ports by 2 cc. at 256/114 to 255/119 for the 049 susposeably these are the desired heads for a stock cast head,,,
Old 11-17-2009, 03:24 AM
ericnova72's Avatar
More for Less Racer
Bad Rat, I think you are misreading that article. It is a comparison of home ported Oval heads vs home ported Rectangle heads. The oval kept their oval shape, and the rectangles kept their rectangle shape. They are both gasket matched to their respective stock port gasket sizes, bowl blended, and have larger than stock valves added(which are a different size between the two heads, which kind of invalidates the results, IMO). The ovals have not been ground out to the rectangle port gasket, which is what you said in the first post.
Old 11-17-2009, 01:48 PM
Bad Rat's Avatar
Wiki Edits: 2
Thats very possable but what I am getting at is when matching the oval ports to the felpro 1211 gasket, [not to the rect port head not enough meat there] and porting the ovals to blend into the rect heads, you get a better flowing CHEAPER set of heads that will flow better than the rect up to around 6500 rpm, better bottomend torque, and ideal for street use,
heres another article from Chev performance Mag on the same subject,, maybe I'm reading this all wrong,, but this is how I am trying to build my
http://www.chevyhiperformance.com/te...ads/index.html
blower motor, and it too late now, i'm down to carb selection ideas now,, this is susposably what this thread is all about,,,
But I certainly appreciate this discussion and looking forward to more,, Thanks guys ,,appreciate the input
Blower or No Blower, That is the question S10 Racer Engine 4 12-16-2007 08:55 PM
6-71 Blower Question Ratoflic Engine 11 11-16-2007 05:28 PM
Mad MAx blower clutch... Augusto Engine 22 03-19-2007 09:03 PM
Will A blower cam work with nitrous. 73camaro Engine 3 09-24-2006 01:59 PM
blower problem fatrat96 Engine 7 07-05-2005 09:28 PM
