blower motor valve springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2006, 07:34 PM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
I just picked up a cam for a small block chebby. It is a blower motor. How much seat pressure are you guys running. A little more info. .500 lift hyd cam. The cam card has no spring info on it just the stuff for degreeing.
Old 09-22-2006, 08:39 PM
Last journal entry: frame build
Need a little more info on the cam. Blowers don't like cams with a lot of overlap and big lifts aren't really necessary. As long as you are keeping your boost in the 5-7 pound range, you don't need high seat pressures
Old 09-23-2006, 06:17 AM
RPM's Avatar
RPM RPM is offline
It is a blower cam with 114 lSA. And I am going to overdrive the blower 10% and make 15 lbs of boost.
Old 09-23-2006, 06:26 AM
garyroushkolb's Avatar
Last wiki edit: How to find an electrical drain Last photo:
blower valve springs
The valve spring specs for the cam should be known by the tech department of that cam manufacture, why not just call them. Also if its a street driven motor you probably won't be abusing it to the tune of 9,000 plus like we do drag race motors. If all else fails contact Chet Herbert Cams as they have a long history on Chevy cams.
Blower timing bailey40ford Engine 8 12-19-2011 04:58 PM
blower idle rpm problem Ratoflic Engine 7 12-01-2008 03:31 AM
Shelby 427 Alum. Fuel Injected Blower Stroker Engine mustangwizard Introduce Yourself 2 01-10-2006 09:15 PM
Diffrent Springs? strikingthematch Engine 3 12-09-2004 09:12 PM
Toyota Camry Blower Motor Problems donemore2003 Electrical 12 11-11-2004 10:45 PM
