Thread Tools Search this Thread share on Facebook
  #1
Old 01-24-2012, 07:22 AM
bkgilley bkgilley is offline
Last journal entry: 1969 Camaro
blower needs fuel
I'm building a chev 454 with a 871 blower I hear it needs 140 gph free flow.
I was thinking about running a Holley black fuel pump through 8 AN lines, and split to two 6 AN. To dual 750 DP. Or does any one have a better ideal on a fuel system?
Register now (free) or login to remove ads
Old 01-24-2012, 11:38 AM
bentwings's Avatar
bentwings bentwings is offline
bentwings
I run a "Blue". AN 10 aluminum line from the tank to the AN 8 short flex line to the regulator then AN 6 to each carb. No problems.......other than excessive noise from the pump.
Old 01-24-2012, 12:47 PM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
Last journal entry: Fresh paint
Wiki Edits: 9
Exactly the same thing I did. If you mount the pump on the frame, vibration and noise will be an issue like Bent says, especially if you have aluminum tubs and floor/interior.
''Life's tough, Pilgrim, and it's even tougher if you're stupid.''---John Wayne
Midnight Sun Street Rod Association
Old 01-24-2012, 04:05 PM
GT23T's Avatar
GT23T GT23T is offline
I'm using an aeromotive pump with AN10 running to a 100 micron filter then the pump then a 10 micron filter to the regulator then -8 lines to the fuel rails and a AN6 return line.
Old 01-25-2012, 12:36 PM
bentwings's Avatar
bentwings
The only pumps that don't make a lot of noise are the gerotor pumps from Mallory or the big Holly pump.
I tried isolating the "blue" pump but it wasn't worth the effort.
Old 01-25-2012, 11:05 PM
camaroman7d's Avatar
camaroman7d camaroman7d is offline
How ae you going to use the car? If it is just a cruiser then what you have planned will probably be enough. If you plan to beat on it, you will want more pumo than what you have. I run a BG Mighty Enduro, fairly quiet, internal bypass, plenty of flow. If I were starting from scratch I would probably go with one of these pumps: http://www.sx-performance.com/Fuel_Pumps.htm
Old 01-27-2012, 01:53 AM
1932bantam 1932bantam is offline
when I ran blown gas in my altered ,I ran a fuel pump to each carb , that way didn't mess with any regulaters , I ran the jegs version of the holley
Old 01-27-2012, 07:57 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is online now
Yada Yada Yada
Two parallel carter P4594 or P4070 electric fuel pumps.
two 3/8" fuel lines, tank pickups and 3/8" in out fuel filters (common in line paper type)
Simple low cost, reliable , no regulator needed. $10 filters.
900hp capable
Noise level is very reasonable when rubber mounted.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "blower needs fuel"
ThreadThread StarterForumRepliesLast Post
Proper fuel pressure for blower carburetorBlackhauk90Engine003-29-2010 03:35 PM
Blower with fuel injection...........??poncho62Engine5901-12-2010 08:22 AM
ideas air/fuel ratios for 671 blower?darkostojEngine002-05-2008 08:43 PM
Roots blower fuel line adviceBANEngine107-24-2007 07:01 AM
fuel injection blower helprichardson110Engine601-06-2006 10:58 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
