Blowers n fan spacers? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2006, 06:44 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Hello.
How do you guys with blown sbc's set up your mechanical fans n spacers? It looks like I need around 5 inches of spacers to clear the blower belt???
Any ideas? HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 10-25-2006, 08:27 PM
poncho62's Avatar
Wiki Edits: 5
I would think that they would use electric fans...............at least I would. 5 " of spacers wont be srable...or safe.
Old 10-26-2006, 02:11 PM
camaroman7d's Avatar
Electric fan/s are the way to go. You don't want to put your fan out that far from the pump. If you do use a 5" spacer you will probably be wearing out water pumps pretty regularly. If you have 5" you can fit a Ford electric fan in there, they move enough air to keep anything cool. The one you want ins off of a Mark VIII Lincoln. You can usually find them for sale on e-bay or you can hit your local wrecking yard. The good thing about them is they have a built on shroud. That's what I used on my Camaro, I don't have the room for one on my Buick (I already tried).
building a fan shroud - need help 32Tudor Hotrodding Basics 30 07-03-2008 09:01 PM
Electric cooling fan Z-Money Pit Engine 1 08-29-2006 08:27 PM
Need advice on a good electric fan set up. Streetmaster Engine 13 01-07-2006 02:37 PM
Spacers behind fan? moodier General Rodding Tech 14 10-06-2005 08:08 AM
? about an electric fan for PU. Streetmaster Engine 8 08-20-2005 10:14 PM
