Blowing fuse at "Brakes/Lamps" slot!? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2013, 02:04 PM
64Joker's Avatar
64Joker
I'm trouble shooting a problem with blowing a 15 amp fuse on the "brake/lamps" fuse-box slot (with ignition off).
Disconnected the entire main rear wiring harness (tail lights, dome lights, courtesy lights, trunk light), but still blowing fuses.
I'm not experienced in reading wiring circuit diagrams, so I have scanned the entire electrical system and attached 5 files.
I'm interested in any other electrical components that should be tested, and additional suggestions would be appreciated.
I'm working with a 10 amp "circuit breaker" tester at the fuse-box as to not blow any more fuses.
Additional Notes: There are no other electrical issues, engine starts fine and headlights and blinkers work front & back!
Application:
Make: Chevrolet
Model: Impala Ss
Year: 1964
Tran: 350 Auto
Engine: 327 cui
Electrical: HEI
Alternator: 12SI 100 amp
ID:	72523   Click image for larger version
ID:	72524   Click image for larger version
ID:	72525   Click image for larger version
ID:	72526   Click image for larger version
Name:	Stock Fuse Box.jpg
Old 03-23-2013, 02:56 PM
T-bucket23's Avatar
Wiki Edits: 26
Application:
Make: Chevrolet
Model: Impala Ss
Year: 1964
Tran: 350 Auto
Engine: 327 cui
Electrical: HEI
Most likely a dead short due to a pinched wire. I would start by disconnecting the battery. Take an ohm meter from the load side of the fuse (THE SIDE THAT IS DEAD WHEN IT BLOWS) to ground. This should show a dead short from what you are saying. a meter with a beeper for the continuity test will make this easier.
Follow the wires from the load side of the fuse and you should find the short. Usually the feed goes right to the break light switch so I would take a hard look at that and also unplug the steering wheel harness as the directionals are probably on that circuit. As you unplug things the short will go away, so you will have isolated the different parts of the system. Common issues are the wires that run in the lower rocker channels, shorts in the steering column.
Does the fuse only blow when you step on the break.
The problem with a car that old is many hands have probably been in there and some may have not been very skilled.
Chet
Old 03-23-2013, 03:04 PM
64Joker's Avatar
64Joker
Follow-up
The fuse blows as soon as I put a new fuse into the slot, no ignition "on" or anything! I will proceed as you suggested. Thanks!
Old 03-23-2013, 03:13 PM
EOD Guy's Avatar
I'd start by unbolting the fuse box from the firewall and look for a broken/frayed wire or evidence of a short, from there I'd trace the loom and look behind the driver's kick panel, from there I'd look underr the wire chase protector under the drivers side sill plate (I'm not sure if that's where it's at on a 64 but that's where it's at on my 67).
Sounds as if you have a direct short due to a misplaced screw, or 40 plus years of driving, rubbing a wire thru' etc....
Old 03-23-2013, 03:36 PM
I think I'd approach this by testing from the load side of the fuse to the power side of the brake switch.
PatM
Old 03-23-2013, 08:56 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Disconnect the intermediate harness and check again.
The intermediate is also subject to abuse, but the only constantly hot wire in there is the dome light----may very well be a black wire in that harness.
(Black and white are also common older GM dome circuits---black is hot--white is return)(turns out 64 is orange/black feed with a white ground)
If the fuse will stay together with the intermediate unhooked---it will be dome light issue---might be as simple as a bad terminal in the dome light.
BTW--that connector is behind the driver side kick panel or just above it.
will be an 8 conductor connector with 7 wires in it.
If not this harness----could be the orange wire from the fusebox to the
brake switch----or an orange wire feeding the headlight switch
(might be orange and black)
There is a splice in the harness coming from that fuse that feeds:
Brake lights---taillight feed---dome light feed---clock
These are the 4 items you need to look at.
Even if you have no clock---there is a feed for it in the harness
Dome lights---remove all the bulbs--or disconnect the harness to the dome/courtesy lamps.
Disconnect the headlight switch connector----eliminate a shorted switch
check for a bare or shorted wire near the brake light switch.
64 must be the year GM started changing some wire colors.
half of the colors on your drawings match my 59--but some are more current and are closer to the current standard.
Old 03-24-2013, 10:36 AM
64Joker's Avatar
64Joker
Follow-up Question
Could this problem by any chance be at the "ignition switch"?
Old 03-24-2013, 12:40 PM
64Joker's Avatar
64Joker
Bryan, Could this problem by any chance be followed back to the ignition switch??? Thanks, Al
Old 03-24-2013, 06:48 PM
64Joker's Avatar
64Joker
Update
I think I've found the problem, after further analysis, it appears the issue is leading back to one of the "console" lights!
I will have to trace it back tomorrow and report back!
Old 03-24-2013, 07:57 PM
Bryan59EC's Avatar
My personal belief is that you will find something with the dome/courtesy circuit.
Don't know where the connector is for a 64 Chevy console, but 66 Chevelle had
a pigtail in the main harness (only on console equipped cars), a short harness about 15" long that connected to the console harness.
Probably 3 wires in that console----
orange wire---feeding courtesy lamps lamps and branched out to a console clock if equipped.
grey wire----shift indicator lamp--clock lamp
white wire-----dome/courtesy ground
no common black wire for ground---common will probably be a screw or clip attached to a console bracket.
Old 03-25-2013, 06:46 PM
64Joker's Avatar
64Joker
Update - Fixed!!!
Traced the issue back to a 2 wire connector off the main console pigtail.
After disconnecting the plastic connector (black/org & black/white wires), the 15amp brake/lamp fuse stopped blowing! Whoo Hoo! All tail/brake lights and courtesy lights now working.
Now to trace the actual issue at the console level, should be a simple fix!
Thanks for all your help fellows!
Old 03-25-2013, 08:31 PM
EOD Guy's Avatar
Good to hear you got it narrowed down
Kill Swith "Keep-Alive" bypass fuse rating kbuhagiar Electrical 4 07-17-2011 11:54 AM
No power from "BAT" terminal on fuse block for3300 Electrical 2 07-16-2010 07:17 PM
Chevy 355 Blowing Oil "help" dran04u Engine 4 10-15-2004 12:07 AM
Hey croz look """"IMPORTS SUCK""" 78 monte Hotrodders' Lounge 14 08-30-2002 02:13 PM
