Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Blowing fuse(s) at ign/acc at fusebox
Old 09-21-2012, 11:37 AM
64Joker's Avatar
64Joker 64Joker is offline
64Joker
EOD Guy - Follow-up
I have an "External" alternator original setup:
As suggested, I unbolted the volt reg from firewall, removed the ground, then reconnected the hot wire harness and the ign fuse did NOT blow.
After removing the volt reg, I inspecting the back of it and it looks pretty darn corroded and rusted!
So, it wouldn't be that expensive to replace the volt reg at this point.
Question:
Would it make sense to test the HEI dizzy module at this point. Would it be a valid module test without the volt reg installed, or should I wait to run the module test after replacing the volt reg.?
