help? i have a 78 trans am i keep blowing fuses for my headlights? sometimes they last a couple days and sometimes they last 5minutes i traced as many wires i could find and even put in a new headlight switch no luck?it has the fuse box that
take the glass fuses and i put in 31 -32 v fuse thanks |
ok thanks .the headlights are older than dirt and the brass terminals are loose on them
To me it sounds more like a wire grounding out occasionay. first place i would look would be under the carpet by the dimmer switch to see if
one of the wires isulation is wore thin as for the headlight swith i dont beleve the lights are fused untill after the switch. the circuit kinda goes like this>> bat headlamp switch out from switch with head lamps and park lamps to fuse box then out from there |
