blown 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-10-2007, 12:04 AM
blown 350
sorry for the stupid questions but im going to build a 350 the block will be line bored and bored 30 over 4bolt i have a new steel crank eagle i beam rods trw flat tops going to get a set of patriot alum heads should be 9 to 1 compression i have a b&m gear drive and a b&m 144 blower the cam i was thinking of was 224/236 113 sep hyd flat its going into a 73 el camino it has to be a daily driver i want to cruse it fri night and sound intimadating also drag it once and a while will this combo be reliable? any suggestions? im trying to do a 70s retro thing two tone paint ansen sprint wheels 8 trac and so on. thanks for any help.
Old 09-10-2007, 08:55 PM
i forgot i have water injection on the car now.
Old 09-10-2007, 10:14 PM
blown 350
my opinion, 9:1 is too high for any blower,8.5 min,7 and change better.Don't know about water inj.but ya might need it for detonation.you did'nt mention lift,not much needed w/"stuffing".
Old 09-10-2007, 11:29 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
I can tell you that I have a 9.7:1 350 with a 142 running 6 psi of boost and it runs great. The solid lifter cam is 236/236@.050. It's also a two bolt main with the factory cast crank and I'm not afraid to take it to 6000 rpm. I've had the blower on it for almost two years now without any problems.
There is one catch though. It will run on straight 92 octane without any issues if I'm just cruising lightly but if I drive it harder (which I usually do) I have to mix about 20% 114 in with 80% 92.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 01:38 AM
Bog/Black Smoke on Olds 350 at 3000 rpm JohnTN Engine 4 03-17-2009 12:39 PM
possible 350 block purchase - comments please idrva55 Engine 17 12-09-2007 10:29 PM
Blown Chevy 350 T man Engine 8 02-06-2003 12:52 AM
Building a Blown Chevy 350 DDent Engine 4 06-05-2002 09:31 PM
