blown 383 heads and cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-24-2008, 10:44 PM
I have a shortblock with forged internals , pistons are dished . I have a weiand 142 blower . the ignition is a msd 6al and a retard box , I am looking for suggestions for a roller cam conversion and heads for this motor . The carb is a 4150 holley worked by the carb shop to flow 930 cfm . will be run on pump gas .
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 03:50 PM
SBC valve spring & cam timing 383 jsteve068 Engine 2 07-04-2006 03:40 PM
383 stroker block and cam ???????? mupton Engine 1 01-26-2006 09:50 PM
Chevy 383 - Heads and cam - recommendations? canter Engine 18 09-02-2005 04:29 PM
383-- use the vortec heads? what cam? slonova Engine 10 02-02-2004 11:45 AM
