Blown 496 cam recomendations - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2011, 01:36 PM
I'm convinced my cam is wrong for my combo. a 8.5 496 with 420 megablower 1-1 ratio. Dual holley 4777's. Goal was cruising 2000 in 5th gear. Engine came with a hyd roller .640 lift 114lca on 109 icl. Has 10hg idle vac. at 1000rpm locked at 32. Don't know duration but must be big. Engine builder and I don't talk anymore, another story. Chevelle with 29" tires, 390 gear and tko600 trans. Will not boil the tires on rolling start. Leak down good, 140lb cranking. Runs like a worn out small block. It idles shaky like too much timing. It runs best at 20 degrees but is really a dog then. This winter it comes out and something changes.
Old 10-01-2011, 03:30 PM
techinspector1's Avatar
Wiki Edits: 326
I'd start by talking with the tech guys at Blower Drive Service...
http://www.blowerdriveservice.com/blowercams.php
Old 10-02-2011, 07:36 AM
You need a little cam to run well at 2000 rpms. Which would have about 17 to 19 inhg of vacuum at idle (not 10 inhg). I would guess you have about 30 or 40 degrees to much cam duration.
However, 8.5:1 cr in a blown BBC would be very high compression for a mild cam.
I think you would need to drop the compression into the low 7's:1 and install a cam with 215-220 degrees at 0.050" on the intake, another 10 degrees on the exhaust, on 114 lsa.
Blown Head Gasket - Do I replace both or just blown one leejoy Engine 1 09-08-2009 03:30 PM
Recomendations dwestmor Suspension - Brakes - Steering 2 06-01-2007 01:57 PM
how much jet is a jet... recomendations?? corona jon Engine 12 10-17-2003 11:27 AM
blown smallbock??? or blown small block? bdv Engine 0 01-27-2003 07:08 AM
what is a better car, a 32 Ford 5 window blown or a 55 Bel Air blown???? hot_rod_kid Engine 9 07-22-2002 04:07 PM
