Blown 496 carbon fouling middle cylinders - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2012, 09:50 AM
What am I missing? I have been tweaking the idle on all eight corners to get the A/F at cruise from 12.2 to 13.5 range. I was using #1 as a guide going from light tan to gray as it leaned. I have an intermittent miss at steady speed and the MSD cap and rotor looked pretty crusty so I replaced them. When I pulled the plugs 3,5,4 and 6 were carbon covered and the others look like #1. Wires are all under 200 ohms and cranking compression is 160 on all 8 holes. After 50 miles last night the outer 4 are off white and the inner 4 are off white on one side and black on the other half of the porcelain.
Idle a/f is 12.3 and leans to 15 on light acceleration then will quickly drop in to 11's as I row through the gears. Same on highway.
My set up is:
8.3-1 496 locked 32 timing
420 megablower 1-1 6lb boost
Edel Perf RPM heads
dual 650 dp man ref Holley's QF blocks 9.5 pv's stock ifr
Lunati 114lca 109icl 240/245 @ .050 .647 lift hyd roller
TKO600
29" tall Mickey's
3.90 gear
cruise at 60 in 4th - 2600 5th 1900
Old 05-17-2012, 10:57 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Mark the inner plugs so you know the position of the black side of the porcelain to the exhaust valve guide- you may be pulling oil in through the guides.
blown 496 timing issue Blown496 Engine 4 10-10-2011 09:19 AM
Blown 496 cam recomendations Blown496 Engine 2 10-02-2011 07:36 AM
In the middle of a road trip! 2 questions! Lean cylinders and noisy rockers? stroker444 Engine 3 09-24-2010 05:25 PM
oval or rectangle port heads for blown 496 mean_1 Engine 9 07-22-2004 08:14 PM
what is a better car, a 32 Ford 5 window blown or a 55 Bel Air blown???? hot_rod_kid Engine 9 07-22-2002 04:07 PM
