blown 496 timing issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2011, 05:22 PM
420 Mega Blown 496 hyd roller has dual 4777's. 114lca on 109 icl. I had locked timing 32 timing. Idle was rough at 1000rpm. Seemed to like 20 better but soggy running. I put the curve back in with 20 idle and 36 total and it runs much better. I think I could go up to 38 and it would be even more crisp. Kinda defies blown big block logic. TDC is right on. Any ideas?
Old 10-09-2011, 05:40 PM
It has always had a shaky idle and a faint surge at 1800-2000 cruising. If it is much leaner than 13.0 at idle it will lean nearly die and recover when clutch in and off throttle. I have it at 12.3 and it cruises in low 13's. Will lean into 14's then 11's when mains and pv's come in. All that seems fine. My engine builder said 32 locked and drive it. If I tune all 8 corners for best vacuum it is lean. Will not fatten into a rich roll. Very odd.
Old 10-09-2011, 06:30 PM
All this is new Edlelbrock perf rpm heads, new blower 4777's with qft blocks and mds6al with 85551 dist. I had the carbs apart and blew cleaner through all the holes and put in new 6.5 pv's. I set the primarys at .020 and rears closed plus 1/2 turn open. Ifr's are .031 iabs stock non adjustable. Without pcv screws out 1 turn without are 1/2 turn. Plugs look off white. Could the cam be too advanced and timing is needed to make up for it? 10hg seems low. 140 cranking. Engine kinda idles like an old 30/30 duntov unless it is retarded to 20 max , rich and soggy.
Old 10-10-2011, 07:11 AM
The idle air bleeds may be non adjustable but I bet they need tuning.
(especially with non (holley) stock QFT metering blocks)
I thought about going back to the stock size ifr but not sure how much more the idle screws would turn out.
All possible ".640" lift" (w 1.7:1 rockers) lunati hyd roller cam lobes are very long .050" duration.
I'm leaving a message for my engine builder today to see if he will share the profile.
Not going to be happy cruising at 2200rpm. The cam is way too big if you want a low (2200 rpm) cruise rpm. Big cams have a rough idle and need more rpm.
I thought that trailer hitch surge at low rpm could be cam but still there even at 2800 when I run in 4th gear. Goes away accerating can feel it decelerating.
Plugs should colour tan after some running time.
They may be on the way there. Not sure how msd and .400ma coil affect it.
What happens when you test the engine idling at 2200 rpm?
At 1300 it has a shaky spot then smoother at 1500 and 2200 it is smooth with 16hg vacuum at 32 total.
Does it missfire, or stumble? what happens if you block/partial block the idle air bleeds with your fingers while doing this test. Does the motor smooth out?
Will do the iab test today. Has never stumbled or bogged even with 20 total.
What happens when you increase the locked spark timing to 38-40deg.
(no WOT running under boost) just test at idle and low rpm-light throttle cruise.
I cranked it up to 40 and it is crisp and responsive off idle. I also drove it at 36 and it really stepped up the torque with great low speed 4th gear acceleration uphill. For the first time it would break the tires loose in 2nd gear at 30 with a medium push on the gas. I am sure at 40 it would be easy to spin the 29x18 Mickey radials with a 3.90 gear.
Old 10-10-2011, 09:19 AM
I hope my engine guy will respond. He thinks I'm neurotic and over thinking this thing. I was fouling plugs and burning oil until I put on viton seals which made me an unhappy camper after spending a ton of money to get the best stuff. I have great respect for him but never had this much trouble. It would be easier to switch my 6al to a btm and go but I would prefer to be cruising and do it right and change cams. I've listened to many blown streeters that run great, sound great and idle like a stocker. What do I need here?
Blown big block timing Blown496 Engine 4 09-22-2011 05:21 PM
blown 400 sbc timing? nastysmallblock Engine 11 05-18-2011 10:29 PM
2001 aztek brake pedal issue after blown wheel cylinder fast68 Hotrodding Basics 1 10-06-2010 08:23 PM
Proper Timing For A Blown Sbc hotstang3 Engine 7 07-11-2005 07:51 PM
