Blown ad stroked - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2013, 12:59 PM
Blown ad stroked
so with a tall deck dart sbc 9.325 with 4" stroke, je forged 32cc with 1.445 height and a 5.85 rod, brand yet to be determined . That puts it at .030 in hole. I have never built a tall deck blown motor. Is there any negative impacts from this set up? And negative Impacts of shaving deck down .030?
Old 04-26-2013, 02:30 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
Stacked parts method adding that up, is going to give you where your at.
Old 04-26-2013, 02:32 PM
1Gary's Avatar
Yeah,buying headers.$$$$$$$$$$$$$$$$$$$$
Old 04-26-2013, 02:44 PM
Banned
Your rs ratio is pretty bad, you can fit in a longer rod if you haven't ordered any yet. It will help wear and balancing.
Old 04-26-2013, 03:22 PM
Was trying to just fit together without ordering custom pistons, can't find an off shelf piston to fit 6" rod unless I'm missing something
Old 04-26-2013, 08:54 PM
vinniekq2's Avatar
why a tall deck and only 4 inch stroke?
Old 04-26-2013, 09:01 PM
Want to keep a good compression height on piston for forced induction. Posting here for suggestions.
Old 04-26-2013, 11:16 PM
1Gary's Avatar
Just so I have a clear idea,you bought a tall deck and want to cut it down??.
Old 04-27-2013, 06:06 AM
Haven't bought anything, wanted to stroke 400 with 6-71 with shelf parts, I can do custom pistons if have to.
Old 04-27-2013, 07:42 AM
vinniekq2's Avatar
the LS-427 is very popular in the turbo charger community.These people are making over 1000 HP in the street cars.The parts are readily available.
The talldeck generation one guys build 472s when they dont want a big block. The gen 1 434 low deck has many choices for pistons with little or no wait.Heads are available with 80 cc combustion chambers. Its hard for us to second guess what the final goal is and best way to get there?
The Following User Says Thank You to vinniekq2 For This Useful Post:
1Gary (04-27-2013)
Old 04-27-2013, 07:52 AM
Banned
I Second the Ls engine suggestion. It's a better design and will cost about the same. No reason not to go that route. You can still get an aftermarket block and go with a stroked and blown combo.
Blown Head Gasket - Do I replace both or just blown one leejoy Engine 1 09-08-2009 03:30 PM
nitrious or stroked? imagine that customs Hotrodders' Lounge 6 06-10-2005 09:57 AM
stroked erythnul Engine 5 06-01-2005 07:32 PM
blown smallbock??? or blown small block? bdv Engine 0 01-27-2003 07:08 AM
what is a better car, a 32 Ford 5 window blown or a 55 Bel Air blown???? hot_rod_kid Engine 9 07-22-2002 04:07 PM
