Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Blown bbc too much crankace pressure
Old 08-12-2012, 09:05 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
If you want to lean on it hard, with boost using pump gas you want a low low compression ratio.
7:1 to 7.5:1 and big ring end gaps.
Engine compression testers have a pressure hold/release valve. The gauge will not drop unless you press the release valve.
