Blown Chevy 292 inline six - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-17-2010, 11:11 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
400 ft/lb ain't stockish- for a 292 inline!
The problem I see w/building a 300 HP NA engine then turning it into a blown engine, is the cam and pistons will automatically have to be replaced. If you're gonna do a blown engine, I would do it w/o any NA stops along the way.
The inline 7 main bearing engine is stout, no doubt. But I would line up a couple cores, just the same.
  #17 (permalink)
Old 08-17-2010, 12:35 PM
Not stockish for that engine but for that vehicle type.
  #18 (permalink)
Old 08-17-2010, 12:40 PM
QParker's Avatar
Six Offender
oh, I've seen the ricers, and that's why I want to beat em! My buddy has an eagle talon, completely stock, other than it going up to 15#'s and that thing really surprised me. I was looking at the turbo and thinking it belonged on my snowmachine while he was burning rubber on all 4 tires (AWD) with a little 4 banger...
  #19 (permalink)
Old 08-17-2010, 12:44 PM
QParker's Avatar
Six Offender
400 foot pounds of torque is stockish for a 1949 chevy pickup that came with a 216 I6 with 95HP from the factory?
I think you got your engines/years mixed up a little there...
  #20 (permalink)
Old 08-17-2010, 12:51 PM
Its stock for a relatively modern truck- which is what I would use to compare it to since that is what you'll be cruising next to on the roads. Go jump in one of your buddies stock trucks and go for a spin, that is about the power you would be feeling with a 400ftlb 292- I would consider that a stockish power level.
  #21 (permalink)
Old 08-17-2010, 01:26 PM
QParker's Avatar
Six Offender
true, but 500 HP out of a 292 is pushing the edge of streetability, maybe I'll get with Tom Lowe, Larry from T6, or Tom Langdon and see what they think.
  #22 (permalink)
Old 08-17-2010, 01:28 PM
You're thinking in terms of NA power. If you run it at 10-15psi 500hp is actually VERY docile.
  #23 (permalink)
Old 08-17-2010, 01:40 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
500 HP is 500 HP. Off boost, an engine can be docile to the point of being a soggy dog.
Relatively speaking, getting a tractable, streetable 500 HP from an inline 292 is getting a LOT from the design, regardless of what is used to get there, IMO.
  #24 (permalink)
QParker's Avatar
Six Offender
I guess, Do you think I should run 8:1 or 8.5:1 compression? I don't want to go above 15#'s it'll probally stay under 10...
  #25 (permalink)
Old 08-17-2010, 01:52 PM
QParker's Avatar
Six Offender
that's exactly what I was thinking cobalt, I just lost words...
While I've got attention who makes good reliable bearings and gaskets for the sixes, mine in particular?
  #26 (permalink)
Old 08-17-2010, 02:01 PM
8:1, could go even lower depending on the cam. 10psi with a 6-71 is not the same as 10psi with other forms of forced induction, there is a LOT of heat gain and no intercooling.
Intercooling would be the next thing to consider, especially in this case. Getting your temps down and your density up can really make a difference.
  #27 (permalink)
Old 08-17-2010, 02:33 PM
QParker's Avatar
Six Offender
It'll have the water/methanol injection, won't that cool it down enough, or will I need something else?
  #28 (permalink)
Old 08-17-2010, 02:39 PM
That'll greatly help, but you can always do better. That is a great first step though.
  #29 (permalink)
QParker's Avatar
Six Offender
You can see my cam specs on the first post, should I change it in any way, or is it fine? I was thinking a little more exhaust duration, like 235 or so, but what do I know? What compression should I run with that cam?
  #30 (permalink)
Old 08-17-2010, 02:51 PM
The cam is a tad on the big side if you want pulling power, but it'll give you a decent sound and it sounds like that may be important for this project. If sound is a concern I would also tighten the LSA up to a 110-112 and shorten your intake duration by a few degrees. DON'T go any bigger. You don't want a power peak over 6,000 RPM. ideally for a street engine you want it to peak around 5000 RPM so you'll have more power where you'll use it.
If it were my build I would be running a cam with about 215/225 on a 112LSA.
With your cam 8.5:1 compression will help off idle response, but any higher than that and you'll really be sacrificing some power.
Chevy 292 inline 6 oil pan kreuzn1 Engine 11 03-15-2011 02:11 AM
Chevy 292 with HEI kreuzn1 Engine 2 01-13-2010 02:22 PM
292 Chevy Inline 6 69GMC Engine 6 02-16-2003 10:31 AM
292 Chevy 69GMC Engine 3 02-13-2003 06:41 PM
Link to online engine project. Blown Intercooled 540 Chevy on Pump Gas Infomaniac Engine 4 02-09-2003 06:51 PM
