Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Blown Engine Build Help
Old 03-26-2012, 08:37 PM
against all odds against all odds is offline
Banned User
i've been wondering about this dilema myself.
My view is that the only way it can be done is to make a "tray" to house a flat filter that will go between/under the hat and on top of the blower. If fuel is going to be injected into the blower, then the tray must go under the hat but before/above the fuel block.
a) If the filter does cause a restriction (would it really be that high a restriction.....?) then can't we comphensate for that by adding a little more boost? i'd be willing to sacrifice a little power for protection. Has anyone actually shown how much (if any) restriction an inside filter really poses?
2) As far as the streetcatcher thing; My feelings on these products can be summed up in a not so nice word that begins with a "W" and ends with ing. If you're going to do something, then do it the right way. On the other hand, if it's looks you're after then i suppose they're ok. i'm actually suprised D.G. would have these things on his website.
