Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - blown head gasket
Old 10-20-2001, 01:00 AM
aka Duke of URL
Do you have a compression or coolant leak? If compression, the side can be indentified by compression/leakdown test. If coolant, both sides should be pulled and inspected.
Can you remove the header and let it lean against the steering shaft so as not to have to remove it?
