I know that the Renton, Washington (home of the Boeing 737) police department was talked into using Volvo patrol cars a few years ago. It was a disaster. They sure ain't no Police Interceptor, Crown Vic. Bogie |
A bad fuel filter wouldn't do it. It is probably from a poorly maintained cooling system. If you fix it, I would recommend installing a new water pump and get the radiator cleaned and flow tested. Replace it if necessary. Check your thermostat on the stove in a pan of water with a candy thermometer to make sure it is accurate. It would be a good idea to install a new temp gauge to keep an eye on things. Make sure your new head is flat and the block surface are clean. Use NEW head bolts and torque with an accurate wrench to factory specs and you should be good for a long time.
Going by what you said happened, it sounds more to me that you blew the timing chain or timing belt.......But, the puddle under the car shows you blew some seal or another....Check your oil for coolant and check your rad for signs of oil.....Thats the 1st thing I would do.
Ontario Rodders |
Well the car starts but runs rough for about a second then dies, and there is oil and coolant on the air box and intake hoses, etc... I might do a compression test just to be sure but if it turns out to be the head gasket then we're going to buy a diesel truck because it's just more practical and i need to tow a trailer anyway.
you should be able to air charge the cylinders one at a time and look for air bubbles at the surge tank filler neck.Bubbles in the system will indicate a head gasket that is blown or leaking.The blue puff you saw might have been power steering fluid if the engine misfired and turned over backwards. The power steering fluid in the volvos is quite flammable.
It was on the other side of the engine, not near any accessories. It's turbo though so i think it was just it's time to go. I'm thinking about fixing it slowly because i'm probably getting a dodge cummins or chevy duramax truck, so i won't need the car but it will be good for my lil bro to drive in a few years.
What have you got against you little brother? LOL
If you find that the oil/coolant mixture on the ground came to be by an innocuous method, you're lucky. Because usually, this means it's terminal. Unless the car is perfect otherwise, that engine will not be worth fixing, in all likelihood. If the car is worth salvaging, I would put another bullet in it instead of trying to rebuild that particular engine- if it it well and truly blown. Otherwise, I'd wholesale it and never look back. |
The car isn't in great condition either but i found a 1999 ram 2500 quad cab wit a cummins diesel, 4x4, and 4 inch lift for $3000 that im going to look at, so i think i'll just junk the volvo or sell it for parts. |
| Cylinder Head Potpourri | techinspector1 | Engine | 2 | 10-10-2010 05:06 AM |
| Blown head gasket? Air in cooling system | rack | Engine | 2 | 09-06-2009 06:59 AM |
| Blown head gasket | ap0001 | Engine | 6 | 10-13-2004 03:35 PM |
| Vacuum leak? Blown Head Gasket? | ewingr | Engine | 2 | 09-07-2004 11:47 AM |
| blown head gasket | nick | Engine | 2 | 10-24-2001 01:22 AM |
