Blown Headgasket?
you can pull the plugs and pressure test pump the radiator
to see . or pull the oil pan and see if from above . but you need to get that water off the crank soon , rusto . |
I'm aware of the rust issue, but I think I might have found the problem. I checked the intake manifold bolts and they were extremely loose so I tightened them down and replaced the oil. Ran the engine for 5 minutes and checked the dip stick...looks normal. I'll pull a valve cover just to be sure but I think that was the problem.
You may have already damaged the bearings depending on how long it ran.
| All Roots Blown Cars Here Please!!!! | AFBCamaro | Engine | 5 | 06-21-2009 07:53 AM |
| TCI Stall Converter - Blown SB | 68NovaSS | Transmission - Rearend | 10 | 09-09-2008 12:42 PM |
| blown injected motors | blown 460 | Engine | 2 | 10-11-2005 08:22 PM |
| blown head gasket - need help to make choices | dbuff | Engine | 4 | 08-16-2004 01:05 PM |
| Virginia Drivers of Blown Cars | Flywhel | Hotrodding Basics | 0 | 01-12-2004 11:28 AM |
