#16
Could be the blower discharge pattern is making the center cylinders rich and the end cylinders leaner therefore giving you a good average AFR if you're measuring at the collector.
Are you set up to check AFR at each primary pipe, or EGT? Are carbs mounted in-line or side-saddle? Could be a matter of just using dis-similar adjustments on the 4-corner idling if these carbs have it. Leaner to the center of the blower and richer outboard. Register now (free) or login to remove ads |
#17
sbc blown too little fuel
Turns out I did one thing right (posting for help on this bulletin board). As for everything done incorrectly, or at least needing correction, here we go.
Timing: initial was 12; moving it to 16 (and 34 total) reduced the EGT. Jets: carbs came from Holley with 73 primary and secondary; installed 75 primaries and 80 secondaries. Power valves: came with 7.5 power valves; after finding 7 inches hg at 14.0 A/F in Drive at 900 rpm and 12 inches hg at 13.6 A/F in Neutral at 1350 rpm, swapped in 4.5 power valves front and rear. Accel pump arms: one was bent; adjusted all to .010. Accel pump cams: retained red/maroon pump cams. The result: center pipes no longer glow red at idle. Chassis dyno at WOT yielded 11.5 A/F, RWTQ of 416, and RWHP of 435 (which translates to about 515 hp at the flywheel). Thanks again to everyone who responded with extremely helpful thoughts ! |
#18
First off. Thank you for responding with the positive results.
Secondly Enjoy |
| Thread Tools | Search this Thread |
| Similar Threads for: "blown SBC with too little fuel flow below 3k rpm" | ||||
| What should my fuel pressure be at idle through max rpm? | scapegoat | Engine | 11 | 10-21-2008 11:35 PM |
| Still Having Fuel Flow Problem to QJet | JohnTN | Engine | 5 | 09-06-2008 03:10 AM |
| vapor lock, sbc, hot fuel pump | Walker | Engine | 1 | 07-19-2004 10:31 PM |
| 434 sbc...what fuel system should i run? | 68SSMaro | Engine | 5 | 05-08-2004 03:10 AM |
| Longblock for blown sbc. Howz it sound? | HemmiGremmie | Engine | 5 | 10-01-2002 10:32 PM |
