blown,spark plug eater - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2002, 12:27 PM
Unhappy blown,spark plug eater
I have a 71 Corvette 327, blown, 6-71, with 2 holley 700 and msd ing. The motor was just redone. On the dyno the fuel mixture is right. In the car it fouls a set of plugs every 60 to 70 gallons. Is this common? Someone asked me the other day the same ??? Any ideas?? Thanks
Old 01-06-2002, 12:56 PM
Post
What type of plugs are you running? You may require a hotter set, maybe R45's.
Old 01-06-2002, 02:26 PM
Post
You didn't say whether thay are oil or fuel fouled.If its fuel go up a step at a time with plugs,don't make any big changes at one time. The dyno and the street are two different things and I would think you are rich at idle or plugs are too cold
Old 01-08-2002, 03:02 PM
Post
Doug, do your carbs have electric chokes? If so you may need to lean out
the choke settings, your problem may be a matter of accumulation during
periods at idle. If you can't stand behind the car(at idle) without being
immediately fumed out then yes it still too rich.C'ya, Jooooooe
Old 01-08-2002, 10:05 PM
Post
Why don't you take a five gallon bucket and pour the fuel in. This is a case of over do for the street. Two 450s would be more like it.It just won't burn that much fuel driving around. ROY
Old 01-09-2002, 04:30 AM
Post
Funny how sometimes the most obvious answer is the most over looked.
