blue poly foam for headliner idea - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-31-2003, 09:35 AM
New Member
Exclamation blue poly foam for headliner idea
i have a 66 nova and i am thinking about doing a headliner in it iwas thinking about using the line blue foam contractor put on the out side of homes before they vinil side it not the 1/2 inch stuff the thin stuff i think it cost 30 dollars at lowes has any one ever don this or something close to it or is there a better idea out ther i have no real curves the car iis mostly a box i am concerned about the the where the roof and the old sail panels would use to go as to how i will make that transistion hey guy help me out if you can thanks
Old 08-31-2003, 06:40 PM
Jag Daddy's Avatar
1969 Mustang Coupe Project Car
Last journal entry: New Project Mustang, From Jag Daddy to Stang Daddy
What are you going to cover it with? It will make a difference. Not being to familiar with your car, is the transition a sharp angle or a smooth transition? You might try taking a razor blade and scoring the material every 1/2 inch or so. Not all the way through but enough to allow the roof side to open up and the interior side to compress. this will allow for a nice curve to form. Then you if your using a cloth type material try buying the headliner stuff with the foam backing, it will help cover some of the ruff spots.
Regards
Mark
Old 08-31-2003, 07:08 PM
stoneyone2001's Avatar
New Member
I don't know much about interior work but I us the blue board a lot you need to check your glue on the board some type's of glue will melt the board But they make an ISO insulation we use on the roof and a thin fan fold Styrofoam board that has a paper backing that the glue want melt if you can find a roofing company that does flat roof maybe the can spare a few or maybe you can buy some through them.
Old 09-01-2003, 07:52 AM
New Member
I forgot to tell you we use a foam type glue called insta-stick to glue the blue and pink and white boards to about any clean surface's most liquid glue's (windshield,super glue etc) melt the boards. I don't know about the spray adhesive you would use to glue the cloth or vinyl. I would test and see!
Old 09-01-2003, 08:44 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
No good. Not flexable enough.
Kevin
