Blue smoke ...?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-12-2009, 11:51 PM
Blue smoke ...??
Trying to figure this out.... if I make a hard run at high rpms 5800-6100 for a bit I get blue smoke on decel.. its like a big puff then its gone.. only on decel when I snap the throttle shut quickly.. and only when I've been at high rpms for more than a couple seconds.. Any thoughts? Top ring gap is .034 bottom is .020. No blue smoke any other time. Valve seals and all are new in the heads. Could this be b/c of the large pull of vacuum when decel happens?
Old 12-13-2009, 09:10 AM
Nope breathers to the atmosphere on the valve covers.
Old 12-13-2009, 04:45 PM
DoubleVision's Avatar
I would call this common fold as it`s not much different than some stick shift vehicles that let out a puff of blue smoke when they shift gears. Unless I could see a pattern of oil usage I wouldn`t worry about it.
Old 12-14-2009, 04:25 PM
lg1969's Avatar
Google "Tunnel Ram 406"
Restrict the oil flow going into the rockers. Or the oil drain back is resticting the flow of oil back in into the oil pan. In any case you may have too much oil around the valve train.
Old 12-14-2009, 05:31 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That's a lot of gap- enough for a 6.5" bore, no nitrous.
Other than that, a high volume oil pump could be flooding the upper cylinder heads.
Old 12-16-2009, 11:54 AM
I'm guessing its the ring gap and the sudden vacuum is pulling it up... It doesn't smoke at all not even a little bit any other time... so I'm not thinking its anything going faulty. I'll keep you guys updated, I just swapped intakes and re did my rr's to get it ready for the dyno tomorrow.
Blue Smoke at idle/deceleration, good compression, new-ish motor, new heads Brentmc Engine 31 05-22-2009 12:16 PM
Light blue smoke, heavy gas smell.. Q JET Sin7 Engine 3 09-17-2008 04:04 PM
Ping, blue smoke, - repeat daveEM Engine 1 07-03-2006 02:22 PM
constant whitish blue smoke greg johnson Engine 3 07-06-2004 02:03 AM
blue smoke panhead65 Engine 11 01-04-2004 04:26 PM
